Since installing a conventional wood boiler in place of our wood prior wood stove the number of cleaning went from twice a season to every 3 to 4 weeks. We have a cape and the roof is very steep and im not getting any younger so a machine to do what I dont want to was in order.
This setup is simple, got all supplies at Tractor Supply or Home Depot. THeres a crank handle in the basement and a pulley house on top of the chimney which a cable is run in a loop around the two ends with a brush connected to both ends of the cable. THE cable goes around the bottom drum a complete turn to give it grip on the cable.
Takes about 50 cranks to get it up to the top and another 50 back down, this will allow cleaning the chimney once a week and keep it complete clean.
This is the pulley house on the top, its just set on the ridge of the liner and held in place by the cable tension
This is the crank handle in the basement, its up off the floor which is nice, I had another opening in the chimney where our oil boiler used to be that I was able to use for access to connect the cabling up through.
Other side of the bottom shaft mount
Heres a overview of all the parts involved in it.
If you want to see detailed pictures of each part you can see all of the pictures at this link
http://s103.photobucket.com/albums/m132/mjenphil/Chimney Sweeper/
~ Phil
![Mechanical Chimney Sweeper installed, no more climbing the roof in the winter! Mechanical Chimney Sweeper installed, no more climbing the roof in the winter!](/talk/proxy.php?image=http%3A%2F%2F%22http%3A%2F%2Fi103.photobucket.com%2Falbums%2Fm132%2Fmjenphil%2FChimney+Sweeper%2FCIMG2851.jpg%22&hash=e038dc20fc74561cda139bf457695a14)
![Mechanical Chimney Sweeper installed, no more climbing the roof in the winter! Mechanical Chimney Sweeper installed, no more climbing the roof in the winter!](/talk/proxy.php?image=http%3A%2F%2F%22http%3A%2F%2Fi103.photobucket.com%2Falbums%2Fm132%2Fmjenphil%2FChimney+Sweeper%2FCIMG2849.jpg%22&hash=159d7bcda846cac6cb00c329e1480d1f)
![Mechanical Chimney Sweeper installed, no more climbing the roof in the winter! Mechanical Chimney Sweeper installed, no more climbing the roof in the winter!](/talk/proxy.php?image=http%3A%2F%2F%22http%3A%2F%2Fi103.photobucket.com%2Falbums%2Fm132%2Fmjenphil%2FChimney+Sweeper%2FCIMG2848.jpg%22&hash=0dea7e9f563492956b0824948b0d1a97)
![Mechanical Chimney Sweeper installed, no more climbing the roof in the winter! Mechanical Chimney Sweeper installed, no more climbing the roof in the winter!](/talk/proxy.php?image=http%3A%2F%2F%22http%3A%2F%2Fi103.photobucket.com%2Falbums%2Fm132%2Fmjenphil%2FChimney+Sweeper%2FCIMG2819.jpg%22&hash=a3cc99af3a93005ac65eb50e8a34dcfb)
~ Phil
