Hi folks,
I hoped that someone would have some ideas of what's wrong with my stove, perhaps it's happened to someone else.
- btw I have read the generic sticky item on this, but if you read on you'll see it's a bit more of a mystery.
My MCZ Musa pellet stove will not run for more than 20 mins, and claims a burner (igniter) failure as the cause. As the stove does actually light, I doubt it's the cartridge igniter but is more likely to be some kind of sensor issue. I thought it might be because it's not sensing the exhaust temp, but the smoke temp info display shows that it's getting hot and gets above the minimum threshold for the stove to go into run/demand mode.
So far as I can tell, there's no on/off sensor for the exhaust temp, just a threshold on the smoke temp to determine if the stove has reached operating temp.
Any thoughts / suggestions welcome.
Thanks
Thanks
If you don't have this manual already then send me a private conversation with your email and I will send you a copy. It is a more indepth look at troubleshooting your stove that the owners manual doesn't cover.
![[Hearth.com] MCZ Pellet Stove - Error A10 - Burner Failure (not) [Hearth.com] MCZ Pellet Stove - Error A10 - Burner Failure (not)](https://www.hearth.com/talk/data/attachments/154/154580-0a267adc41a79d03320c2a7ab448478c.jpg?hash=vCPHtnUmZQ)
