We still have hopes for eventual success with the Maxim M-175 Outdoor Pellet Boiler (by Central Boiler). But -- Anyone considering the M-175 should expect to add some complexities to their life.
I would describe the support available from the dealer (Northeast Outdoor Furnaces - NEOF in Claremont, NH) and the manufacturer (Central Boiler) as "sparse". The installation / operating manual seems to lack a lot of necessary information. Way too much of the set-up and feed rate / air setting seems to be left to trial and error.
The Central Boiler web-site has good sales information and provides an opportunity to submit testimonials. But -- there is no on-line access to manuals, suggestions, forums, or opportunity to request support.
Installation did go about as expected and documented. We connected directly to a (now) depressurized oil boiler in the basement.
We have experienced significant problems with creosote formation in the top boiler tubes.
Pellet consumption has been much higher than expected based on the estimating factors provided in the "impressive" marketing brochure. Four tons of New England (NEWP) Premium pellets have been burned between October 18th and January 16th out of the 7.5 ton estimate for heat plus DHW for the whole year for this small 1200 sq ft 1950 Cape in Central New Hampshire (based on the conversion for 850 gallons of oil).
Cleaning has been more difficult, frequent, time consuming, and messier than anticipated from the brochures, web-site, and dealer visits. You will need old coveralls, and must be ready to kneel in snow or mud. The manual doesn't even explain the clean-out panel latch ( just underneath and out of sight).
The (steel?) areator degraded and finally broke in half. The Maxim would still operate, but with reduced efficiency. The areator was replaced under warranty by a "house call" from NEOF. There is a redesigned cast iron areator now in stock at NEOF. These will be used as more areators fail. So, watch the areator.
Another problem was the "bridging" or crust of pellets which created a void and loss of heat. Also, several times, gravity has not been sufficient to slide all pellets in the hopper to the auger chamber. Two or three bags of pellets remain on the sides of the hopper when pellets stop feeding.
Of course, the week long power failure required getting temporary power to two places. Inverters from cars almost worked.
SO -- Buyer's Remorse - "No Good Deed Goes Unpunished"
I did the research, estimates, made the suggestions, and fronted the $'s to help our son purchase the Maxim last June when pellets were $250/ ton and oil looked sure to hit $5/ gal. We heated our 1790's farmhouse in Upstate NY for 25 years with wood we cut in a Defiant air-tight (plus some solar). Our daughter has had real good experience with a nice little Harmon on Long Island using a couple tons of pellets a year.
The choice was a Harmon which would save a lot and heat much of the NH Cape or the Maxim which should heat the whole house plus DHW and save even more. The ideas of not having to lug pellets into the house, not having the fire inside, not taking up space, and not cleaning inside were all quite appealing.
As the kids on Long Island pointed out after being copied on numerous e-mails, you can just look at their Harmon in the living room and know how well it is burning or soon notice a problem.
With oil now down to around $2.50 and more pellets up around $290, it looks as if all I've accomplished is adding complexity to some already busy lives.
After a couple of days skiing with the grandkids, it will be time for me to fly back to Florida (Frostproof that is) and get back on my bike.
