Master Forge H30xl
mellow
Resident Stove Connoisseur
6,095
Salisbury, MD
Got the Master Forge H30xl installed this weekend, it was a new install with all new pipe. Installed easy enough, very few issues with the stove install itself. I have been running the stove now for about 48 hours, the initial burnoff went well, just had to keep windows open and pointed a fan at the unit so all fumes went out the window.
Pros so far:
  1. Built in Wifi (app could use more options but it works)
  2. Small footprint (clearances are pretty substantial for such a small unit)
  3. Ease of use
  4. Blows out heat
Cons so far:
  1. Blower is not quiet (they call it Whisper Quiet Blower Technology)
  2. Thermostat wire in the back is not reading correctly, sometimes off by 5-6 degrees
  3. Have to set the stove at several degrees higher than I want due to thermostat being off (at 80 currently in eco1 mode)
  4. Glass gets clouded up by flyash pretty quick using P4 mode (simple to clear with wet paper towel)
I will update as it goes along. I have the stove plugged into a Kasa link and I monitor the stoves electric use with Sense if anyone is interested in that. I also do it so I can shut the power off remotely to the unit if the need arises.
As mentioned so far I am running it in Eco1 P4 mode (blower set to -20 to try and quiet it down) so it shuts off once it hits 80 and comes back on once it hits around 75, the issue being the thermostat has such a wide jump, sometimes it will go from 75 to 79 and then back down to 77 within a few minutes. I will work on figuring out if I can make that more stable, I have already tried putting the tip of the wire into a sleeve but not seeing much difference yet.
[Hearth.com] Master Forge H30xl
Reactions: Ssyko and Turbo89
What I see is the temp will drop down to 72 on the stove temp probe which is actual room temperature after the pellet stove turns off. Once it starts up again it jumps up to 75 then will eventually hit 80 and shutdown down again, it is not staying on long enough, short cycling. I used another thermocouple and put it near the stoves temp probe and there was about 5 degrees difference between the two so I have to figure out how to get that temp probe on the stove to be more stable.
Cycles so far today:
Turned on: 7:46 am
Turned off: 9:52 am
Turned on: 10:13 am
Turned off: 1:37 pm
Turned on: 2:12 pm
Reactions: Ssyko
Thanks for the updates, just picked one up on Clearance at Lowes, I have Whitfields and dont know if this will work any better, nice to finally have a Wifi and a igniter for once in the past 26 yrs, keep us posted on what more you find, at the store i didn't see any heat tubes that would blow any air out front, and whats up with the removable front top cover?, you can see the burnpot area, so air just blows all around it, does it actually have a decent amount of air pushed out the front grill?
Reactions: Ssyko
Yes, I have actually played with the P settings and now have my p1 set at exhaust fan (S) at 15 and the blower fan (F) at 10 and I am getting more heat out of the unit.
My issue with the thermostat is the unit is in a small room so I need to get the hot air out of it to the other rooms more efficiently, I am working on that.
Reactions: Ssyko
Wanted to post an update, I have fixed the temperature issue by adding a Vornado fan to the same room as the pellet stove to blow the hot air out into the rest of the house. My temperature in the room with the pellet stove has come down now and I can run the stove at lower temp settings. The stove now keeps the entire house (1600 sq feet) at around 73 degrees, I did not expect that from a pellet stove of this size nor am I pushing it hard to do this, most of the time it is running in P4 mode which is low. And this is while the temperature outside has been in the teens with windchill.
Some other pictures of my fan setup:
This picture shows the location of the Vornado on top of the bookshelf:
This picture shows the warm/cold air currents I have created with the Vornado to move the heat out of the room to the rest of the house:
I now keep the ceiling fans OFF as they are not needed with the Vornado running on medium. The open door allows the heat to run the full length of my house all the way to the bedrooms on the other side of my rancher layout, it is a straight shot through the living room and down the hallway. If things get to hot in that room I open the other door to the kitchen.
Reactions: Ssyko
So I made the Vornado a smart fan. I have hooked up a temperature controller to it so it turns the fan on at anything above 70 degrees and turns it off at below 70 degrees. Works well. I don't run my pellet stove at night (let the heat pump run) but I have the pellet stove scheduled to come on at 5am so we come out of the cooler bedrooms to a warm house. I was having to leave the Vornado running all night but now it comes on once the air temp hits 70 and starts blowing the hot air out of the room.
Reactions: Ssyko
The Lowes special $600 pellet stove has done its job for another heating season.
Short of the blower being on the louder side it has ran like a champ and having the wifi ability to turn the stove on or off while out on the road is awesome. It has been heating our 1500sq rancher very nicely with the fan setup I did to get the heat to the rest of the house.
The 30lb Hopper will last more than a day with usual temperatures, but when we will have to feed it more during extended freezing temperatures.
We do have to clean the glass every night when we shut it down. It is programmed to come on a 6am in the morning and hasn't missed a beat yet.
Reactions: Ssyko
Nice setup. Did I see a square vent in the ceiling? Do you have forced air? Does the pellet stove have a mode where it does not use temperature control? I can't believe the pricing.
Reactions: Ssyko
Ducts in the ceiling are for the AC/Heat pump.
It does not have a mode where it doesn't use temperature control, but once you get it figured out and fine tune the burn settings it does good.
Reactions: Ssyko
Do you run the house system in just fan mode? Does it shutdown when the temperature is reached, or go to low? I could use temp
control right now in my basement but I'm not down there all the time.
Reactions: Ssyko
I wanted to do an update as we come out of the deep freeze.
We have been pushing the H30xl pretty hard, running 24/7 to keep our heat pump from running in resistive mode and blowing up our energy bills. The only part I have had to replace so far was the vacuum sensor, and I think that I may have messed that up doing the leaf blower cleaning trick with it still hooked up and the door slightly shut.
Short of that the stove has been doing what it should be and putting out heat. I still clean it once a day, usually right before going to bed so I know it won't have any issues going overnight.
I disconnect the vacuum sensor on my stove every time I use the leaf blower on it for that very reason.
I will from here on out as well, I would always leave the door open or slightly ajar so pressure would build but not damage the sensor but one time the door got sucked shut and the stove didn't act right after that so I replaced that switch and all is good. Lesson learned.
Reactions: Ssyko
