KD - Another solution for a chopping block that is to high is to simply dig down into the dirt and drop the block into the hole however deep you need to make the block sit about 4-6 inches above grade (or your comfort level). Drop the block in the hole and back fill to lock the “stump” into position. Now you have the height you want, and a good solid block that won’t move or split (cause it’s actually taller than 4-6 inches-most of it is just buried in the ground). Can’t believe I didn’t think of it earlier. Just needed your help I guess. Thanks!
Gonna do that first thing in the morning before the frost sets in (which will be soon here in Michigan). My block does have a slightly uneven top to it also, and I agree it helps for the unlevel cut pieces. Glad I could help with the tire gizmo. It really speeds things up. KD
EDIT: I can’t take credit for the tire thingy-I read about it somewhere on the internet.
Glad to have helped out, I hadn't really thought of burying a log, but that makes sense, and I have a couple that would likely work really well for that - couple of feet around, and full of knots. I'd been dreading the notion of trying to split those anyhow. I might not get around to burying them until spring, as I'm mostly done w/ wood cutting / splitting for the season - the sheds are full and my left over rounds are all stacked and tarped for the winter. The monster rounds are either on the bottom of the pile or bracing it up. It also won't be fun digging a hole that's large enough givin that we are in prime New England "rock farming" country... But I can start looking for a tire much sooner than that!
BrotherBart
Back before I decided that pulling a start rope twice beat the heck out of swinging a maul many times, I split on the ground. Still do when the urge strikes me. With the surface area of a ten inch or larger round, if you think you are lumberjack enough to hit it hard enough with the wedge end of a maul for the ground to be absorbing a bunch of energy you are dreaming. Or you have the maul turned around backwards.
Well BB, I've never tried instrumenting things to measure them, but I've watched the earth next to a round shake when I give the round a good whack with my monster maul - it makes sense to me that any energy that's going into moving the dirt isn't making the log split. When I was whacking stuff on my favorite stump, it seemed that I needed fewer hits / split, considering the wood type, but it was hard to tell since what I was splitting on the stump was mostly maple, and the load of log-length I got and was splitting on the ground seemed to be mostly red oak that was easier to split.
Suffice to say that I think it is easier / better to split on a block that's the right height for the same reason a blacksmith finds it easier to whack on steel that is sitting on an anvil...
chrisN:
I always split the rounds directly on the ground. I read somewhere a suggestion to dig a hole and plant a round into it, making the top level with the ground to use as a splitting base. It seems like it would work, but I haven’t gotten around to trying it yet. So I pretty much just attempt to split the rounds where they sit. My rule of thumb is if it doesn’t split after 4 rapid whacks, I leave it and move onto another. I come back to the contrary ones after a while, (sometimes weeks or months later), find it great therapy to just work on one round for 10 or 15 minutes after a day at the office.
I guess I'm more of a stubborn b*****d! I figure that I have to deal with any given piece sooner or later, so once I'm hitting it, I might as well get it over with. I'll whack it with the monster maul for a while, but if that doesn't seem to be getting anywhere I'll grab the sledge and wedges, but the only way a round leaves my splitting zone is in pieces! On the flip side, I've learned to be pretty good at guessing which hunks are going to go easy and which ones will give me a hard time. I try to choose my "victims" so as to get 4-5 'easy' logs for every gnarly one.
chrisN:
kd, I think i’ll try the tire method next time. I happen to have several tires left over from my summer gardening experiment when I attempted to grow potatoes in them. I didn’t work for me nearly as well as I had oped.
I eat low carb, so I have no interest in potatoes, but I've had pretty decent luck growing hot peppers in tires. My bee supply lady raises llama's so she is always looking to get rid of 'llamadoo' which is an excellent fertilizer (It's nice to have friends who will give you $#!T on request....) I used a hole saw to cut a few holes one of the sidewalls of a bunch of tires. I put the tires on a piece of black plastic, filled them with a 50/50 blend of llamadoo and potting soil, then covered the top with more plastic. I then cut a few holes in the plastic to match the sidewall holes I made earlier, and a few more in the center hole, and put about 6 plants in each tire. The effect is a raised bed that is easy to work around. The black plastic keeps the soil moist and helps warm it, as well as discouraging most of the weeds. I've gotten several good crops this way.
Gooserider
