My husband and I have to come to a determination soon as to which stove to purchase...Heritage or Mansfield. We would love to get the Heritage as the set up would work much better for us with the rear vent but we fear it will be too small.
Here are the specifics:
1. We presently have a VC Defiant. It is 24 years old and has done a great job heating our home. We are completely satisfied with what it does for us. BUT we want something more efficient. The BTUs for this VC are in the 55,000 range.
2. Our house is an old farmhouse with 2800 square feet.
3. The stove would be in the middle of the house near a stairway that fans out into most of the upstairs.
Which stove should we purchase? It would sit on the hearth in our kitchen where the VC sits now. A rear vent is a huge plus as it can then sit out on the hearth. With the top vent of the Mansfield we would have to push it back into the fireplace around 9 inches.
Help help!!
Please send your suggestions asap.
The Equinox would be too big for the area. It is either the Heritage or Mansfield...or to throw more out there..the Phoenix??
Thanks!!
Help help!!
Thanks!!
		 The stove gets its primary and secondary combustion air from a 3" dia hole down low on the back, left side of the stove.  It is naturally wide open to the room, and you can modulate the primary intake w/ a lever on the front of the stove.  It draws air from the room, burns it, and sends those combustion gases up the chimney.  This creates a vacuum effect - the house has to let that air in thru all the cracks and gaps in its exterior somewhere.  So you're in essence creating air motion in your house - drawing the freezing cold outside air inside on purpose!  Some people don't like this idea and decide to plumb a little metal duct outdoors to feed the stove.  The fire really won't care what temperature air it is fed to burn, but you should see less draft pulling into the house if you use it.  It is generally not mandatory but I have heard of instances (Highbeam) where inspectors have wanted to see it used when it's available.
		 !!, puts you well past 4500$ plus tax and delivery.
