I've been burning pellets forever(18 years?) with an older Breckwell P2700. It's pretty plain Jane, so I ran it on low pretty much full time from late fall to spring. On warmer days I'd turn it off for a bit. On colder days I'd crank it up a little. I have a 2000 SQ split ranch with the stove on the bottom floor with a big open stairway. This supplies the core heat for the house. Some areas run cold, while other areas run hot, and we're fine with that. The stove has been pretty cranky over the past few years to a point where only I could figure out how to run it. It broke on the coldest day of the year and I decided to stop maintaining it, so I picked up a used 2 year old Piazetta Sabrina.
I just hooked her up last night and I'm trying to figure things out. It burns WAY warmer than the Breckwell. Looking at the manual and various posts, it appears I will have to manage things a bit differently. I ran it on low all night and woke up to a very warm house. It's nice, but kind of too warm and I expect I'll be blowing through pellets, while keeping the house uncomfortably warm downstairs. I've been reading up on the stove on this forum, and will continue to do so, but I figure I'd post something to get some targeted advice.
I saw that you can adjust the pellet rate on these things. I guess I need a code to do that. Should I pursue that direction? I only burn the Douglass Fir pellets and it was never an issue with the Breckwell. I saw some posts that recommended only running it on P3 to keep things burning properly. I would expect that to be too warm.
Should I focus on using the temperature mode where it shuts own and starts at a specific temp? Is shutting down/restarting constantly an issue? Any advise on setting that up? I read the manual and didn't want to go too far in that direction if it's a bad idea.
What's up with the Energy Savings mode? It appears to just slow down the blower fan. Is that a useful feature?
Any other ideas?
Thanks in advance!
Any other ideas?
Thanks in advance!
