Just finished refurbishing firebrick, adding upper row, adding baffle (15x12 1/2) and adding secondary burner (3/4 pipe). Going to make some better draft controllers but the ball valves will be OK for now. Thanks to everyone on the site for the valuable information. Hope someone can use something from these. Here are some pics.Any chance you could sketch out what this looks like in profile? I'm afraid of blocking the flue too much to meet the angle and height from the inside-top of the stove.
I believe my stove is a Momma Bear -- that's what I was told -- but my measurements seem much different from yours. Inside width (minus a half inch) is 16.5-in. The 6-in flue is not flush with the inside rear wall, but protrudes 2.75-in inside the firebox. For me to set a 5/16-in steel plate inside at 45-degrees and 2-in from the inside-top of the stove, it would need to be about 10.5-in wide.
You used a 15 x 8 x 5/16 plate but I think that would be too small for my stove. Am I missing something?
