Well time for another solar upgrade, my new plug in hybrid is using up my surplus generation. I had been looking around for options and one of these caught my eye.
These were built by a company called DC Solar. They had a great idea but at some point the owners got greedy and decided they could do better with Ponzi scheme. They hooked Berkshire Hathaway and Progressive Insurance for 100s of millions. The feds seized the firm and the inventory and auctioned it all off along with a big car collection and lots of personal assets. Most of them were auctioned off down south or out west. It turns out there was inventory in NH tied with the NH motor speedway. I bought mine from someone who bought six of them.
Its an off grid power system on a trailer. They didn't spare much expense on the system components. Its got two large forklift batteries, a kubota 11 KW diesel, fuel tank and most importantly a set of stacked inverters and a charge controller along with 2300 watts of panels on a10,000 pound car trailer (minus ramps). The inverters are hybrid inverters so they can run off grid or on grid. This one came with a pair of light towers that reportedly cover a football field but to me its nothing I plan to get a lot of use from. It puts out 50 amps at 240 volts. The solar panel mounting is a compromise but I have some ideas. The system is designed to charge the batteries with solar and then if the batteries drop too low the diesel kicks on and recharges them. The other use for the diesel is to equalize the batteries which effectively overcharges them slightly. This is needed to keep the full capacity of the battery. These have been sitting for a couple of years and battery life is a question but usually they can be recovered. Worse case is the other parts are worth about what I paid for it.
I may be building a house in a year or two so I will be keeping the trailer complete until them. Therefore a permanent install is on hold. So what to do in the short term?. I have a grid tie system pumping power into the grid through my main panel so I cannot put a transfer switch on the main panel. So right now the plan is pull a bunch of circuits from the house panel to a transfer panel and run the house off the trailer. I do need to revise the panel angles temporarily. The light towers are real slick but with 48 volt LEDs not very useful. I think a ham radio person might have some use for it. I may take them off for the short term but they may be handy on occasion for a house build.
These would be ideal for someone with an off grid camp or in an area with poor power quality. The inverters are Sunny Islands that are designed to coordinate between multiple sources of power and switch from on grid to off grid.
There are several variations of these units out there, this one appear to be the deluxe unit. I have some basic info on them if someone is really interested.
![[Hearth.com] Making a big Solar Upgrade [Hearth.com] Making a big Solar Upgrade](https://www.hearth.com/talk/data/attachments/280/280207-ab15efa1941dd72cb1f4b3e0ec0af6ea.jpg?hash=rvxNgzIlal)
![[Hearth.com] Making a big Solar Upgrade [Hearth.com] Making a big Solar Upgrade](https://www.hearth.com/talk/data/attachments/283/283418-284189bd16fafb19df8186c8f58d716c.jpg?hash=YY5amkuR9u)
![[Hearth.com] Making a big Solar Upgrade [Hearth.com] Making a big Solar Upgrade](https://www.hearth.com/talk/data/attachments/283/283419-e97bbd6045bfc51292401d364fdc23c7.jpg?hash=Wj1J2SesN5)
![[Hearth.com] Making a big Solar Upgrade [Hearth.com] Making a big Solar Upgrade](https://www.hearth.com/talk/data/attachments/283/283420-229d297368bb049f73006d711b0a395c.jpg?hash=1v6Ky9G17o)
. My ankle is definitely still on the mend but I am now able to move around a lot better and even able to do some work on a step ladder. Yesterday was a warm day so I mounted an outdoor box and ran PVC conduit to my main panel, made some room for a dual pole 50 AMP breaker and hooked up all the wires. I tried to put the new function on-line but managed to get an error code. A bit of research overnight and it looks like I confused the logic so I gave it another try today. I turned the trailer inverters on and then turned on the AC power feed to the trailer from the utility and 5 minutes later I watched it go into grid export mode. Only 1.2 KW for now as my panel angle is low for February but as the sun gets higher the output will go up.
