I'm super happy with this firewood tote.
(broken link removed to http://www.motherearthnews.com/Do-It-Yourself/1978-09-01/Mothers-Rope-Wood-Carrier.aspx)
I made two of them with 50' of 3/8" manilla rope (~$6 at Home Depot) and a couple leftover 2x2 spindles from a deck I built. It was no precision job to drill the holes in the 2x2s with the 3/8th drill bit, but it doesn't seem to matter much. The only thing that mattered seemed to be the requirement of knots to hold the middle boards from dropping to the bottom/middle when you carry it. With the ~25' of rope per carrier, and 4 knots in each of the main ropes (one on each end, plus the ones in the middle to keep the middle boards from falling) I can fill the carrier with just about the right weight of wood. I'm no strongman, but I'm just a little uncomfortable carrying two full loads, which is about 24 hours worth of burn time. So I can make a single trip per day to the wood pile.
Anyway, I love the carrier and thought I'd share this with the forum. (It was not easy to find on the web.)
EDIT:
Just realized that I put two middle boards, and the pcitured only has one. One Board is probably easier and all that's required. Maybe mine are a little bigger than the one pictured.
EDIT:
