For decades now, I've cut down standing dead Poplars that either threaten to fall into my yard or that are snapped off or leaning. Basically, if I can drop them back into the bush without doing too much damage to the other trees, then I just make sure they lay flat so as to rot. If and only if I cannot do that, do I buck them up, split them, and give them to my neighbor. I won't burn them in my stove.
For some reason this year, the wife has taken to object to the clutter on the forest floor. Part of it is that we just got a little bit of snow and the downed trees really stand out as straight lines. Where they are close to the edge, I will buck them up to random lengths and scatter them around a bit so as not to form those straight lines. I usually drag the tops over to my burn pile as it is less work to burn them than it is cut them up short enough to make them lay flat. I usually burn the pile down when there is enough snow cover on the forest floor.
Anyway... this year my burn pile got too large, too soon so I had to leave a bunch of small stuff in the bush and do it in two burns. So, I burned down the first pile and started in on the second. The wife then decided that I should also burn the big stuff that I intended to just let rot. In fact some of it was already punky wet and would not burn if I tried. Much of it is between 6" and 12" in diameter.
I don't know what to do short of pray for a foot of snow. The neighbor doesn't want to work for the wood, only wants it if I haul it out of the bush and cut, split, season it, and leave it close to the road.
