I've found that the single most polluting phase of using stoves is the kindling operation at start-up....... I'm guessing that 50% of the pollutants are released at that time. This brings to mind that we can minimize these pollutants by better fuel management but maybe also that burning 24/7 would also minimize this since loading only a hot stove (as opposed to letting the fire die and then re-fire) means that much of these pollutants are burned off in secondary combustion or through the cat device. This fact is supported by the Omni Lab study I was reading. Other factors they mentioned is burning well seasoned wood with a moisture contain less than 20% though I've had success at slightly higher levels (22% or so)...... Stove maintenance (gasket replacements and cleaning out fly ash blocking air passages) can also make or break the GPH coming from a stove....same as with maintaining a car.
