Hello all,
My wife and I purchased this stove used and abused. Put a lot of work into it and now its working great. Well, mostly great.
We have an approximately 1600 sq. ft. home with the stove located in the basement pointed toward the steps going upstairs. This setup has been working great in the plus 20 degree F days to keep the entire home a few degrees above the now backup oil heat thermostat. This is on heat setting #4 with the fuel stirrer on #2 and a thermostat about 15 feet away in the same room.
During the really cold temps here, at least for us, I started cranking it all the way up to #5. While this helped a lot with bringing the temp back up, after about 10 minutes, the stove would kick back to what seems like heat setting #2 or #3. I don't think I'm hitting the high limit sensor as I think that would just shut the feed off and let the stove cool. If I switch it from #5 back to #4 and back to #5 it will start burning hot for awhile then back to slowing down.
BTW, this stove was just a low cost way for us to see if pellets would work for us. We enjoy not hearing the oil burner kick on, So I'm eyeing up a new M55 FS.![Cool :cool: :cool:](/talk/styles/default/xenforo/smileys/shade_smile.gif)
