I have a Magnum 7500 Pellet Furnace, in the last couple of days the auger seems to get stuck, then after a minute it starts up. It has done this 4 times that I know of. What could be the reason? Thank you in advance.
Motor could be getting weak. Something stuck on flights or in the feed tube binding. Temp limit switch failing or unit is overheating and the switch is operating as it should.
