Alrighty Then I'm not one of those hard headed guys. I'm only 3hrs into the initial fire up of the Mag. First off I give it 2 thumbs up triple A+. This dude is pouring off the heat better than the old Nashua I gotta say. Secondary flames are quite the spectacle. No draft issues at all. In fact I have the opposite problem. I'm going to have to put in a damper to limit stove temps. With 4 splits in the stove and primary air shut its running 700 degrees and pipe temp is 400. Best part is 2 hrs later I'm still on the initial load and temps are holding solid. I'll report back in the morning to see how the over night goes. I can already see fuel consumption will be much less. Only thing we have now is to get through the gas off stage. Right now the whole house is IFR. Some have reported smoke when door is opened. Not the case here at all.
OK let the questions come.
