Just pulled the side cover of our new M55 to hookup our programmable thermostat. Once I looked at the circuit board it does not appear to match the wiring diagram so I'm not sure where to hook up the thermostat wires. In the wiring diagram the thermostat terminal appears to be on the bottom of the circuit board, but it does not appear to be there on the actually board. There is however an identical terminal (blue, square in shape with screws) on the upper part of the circuit board (and no, I'm not looking at it upside down ) with two red wires which go to a plug/terminal on the back of the stove. Pretty sure that is the hookup but I'm going to contact Enviro to make sure. Has anyone hooked up a thermostat and encountered a similar problem? Suggestions?
Thanks,
Mark
Thanks,
Mark
