It has been several weeks since I last posted concerning the appetite that my 1 year old M55 Insert seems to have for pellets.
In my original post I explained that I seemed to be burning a lot more than the 3.1 lbs per hour of pellets that Enviro lists as normal. After doing all of the normal things like scrubbing the stove, checking the draft to 1.6 and using multiple brands of premium pellets, (Ligs, Oakies) I still was burning 40lbs in less than 8.5 hours with Heat set to 3, feed to 2, and combustion to 2.
Well after going round and round with the dealer/installer who recommended that I adjust the Auger Restricter Plate, I finally got tired of waiting around for him and pulled the stove and did it myself.
At first I set the Auger Restricter all the way down which only left 1" of opening for pellets. Filled and started the stove and unfortunately it failed. No pellets were feed into the burner pot. I vacuumed the entire 40lbs out and reset the restricter plate to 1 1/2 inches from the bottom. (I have pics if need be) refilled the stove and started it up.
This time the stove ran fine, but I didn't see any major improvement on the consumption of pellets. I got about another hour or so but after doing all the math I am still not getting the specs that Enviro says I should be getting which means I am still waking up in the morning to an empty stove and cold house.
I have since made another improvement to the stove and added a high end Skytech wireless thermostat to the unit. This gave me some relief since the thermostat does a better job of managing the settings while I am sleeping or away from the house.
I am now at the point, that the dealer wants to replace the blower motor with the new Turbo Blower that many of you have mentioned as an upgrade to this years stove.
My question to this board is - "is it worth it"?? Will it improve performance? Will it reduce consumption? Is it very loud? A big concern of mine since it is in my primary living area with TV & Kitchen and noise is an issue.. Although he won't warranty it for me, he is not going to charge me either since I have been complaining about this since day one.
What are your thoughts?? Should I upgrade or not??
Thanks
Thanks
