So I had the old fan on stove. This fan is notorious for being weak and the design has it so it eventually becomes unbalanced at the motor side and starts under performing and making noise. I could tell it was going out because it would not spin as easily when I spun with my fingers, and on the lower stove settings I would hear a constant quiet rattle coming from the exchange tubes.
You can see the motor tilting and the shaft connecting to the squirrel cage at an angle.
So rather than wait for it to crap out in the middle of winter, I decide to be proactive. New fan below:
Goes in like the old one, with two bolts holding it up at each end of the stove. The tricky part is securing the capacitor to the metal bracket that holds the pressure switch. There is screw in the middle of the plate that holds the pressure switch that needs to be replaced with a longer one. This longer screw will hold the zip tie collar which will hold the capacitor.
That is pretty much it. It is a big upgrade from the old, and puts out more hot air. It is a little louder but not much. The Dell laptop makes more noise with its cooling fan.
![M55 Convection fan upgrade M55 Convection fan upgrade](https://www.hearth.com/talk/data/attachments/148/148555-86a4215e357ec5a4ee53fe0e1827855d.jpg)
![M55 Convection fan upgrade M55 Convection fan upgrade](https://www.hearth.com/talk/data/attachments/148/148556-428282dfd633d910b990e01a83b9c322.jpg)
![M55 Convection fan upgrade M55 Convection fan upgrade](https://www.hearth.com/talk/data/attachments/148/148558-f4edd4c69422c3ad91eb2d719cfa0756.jpg)
![M55 Convection fan upgrade M55 Convection fan upgrade](https://www.hearth.com/talk/data/attachments/148/148559-0328e4d8634511d70dd11be585431c23.jpg)
![M55 Convection fan upgrade M55 Convection fan upgrade](https://www.hearth.com/talk/data/attachments/148/148560-5c838699fd42886b590aad387f9b5cc4.jpg)
![M55 Convection fan upgrade M55 Convection fan upgrade](https://www.hearth.com/talk/data/attachments/148/148561-8ba56d365ec2cd1b2ea5367577eb8b71.jpg)
![M55 Convection fan upgrade M55 Convection fan upgrade](https://www.hearth.com/talk/data/attachments/148/148562-765714ee38ebcbd7e45d9494f125cd7d.jpg)
![M55 Convection fan upgrade M55 Convection fan upgrade](https://www.hearth.com/talk/data/attachments/148/148563-f1c434d5b0374d532e7cf42923e093f9.jpg)
