Lube those door hinges on the Econoburns
Huskurdu
138
Southwestern NY
The "leaky gasket" thread reminded me of something. When I took the top door off of my Eburn 150 the pins on the hinges were well worn. I put some bearing grease on them and reinstalled. They work much better now.
Just something to think about when your working on your door gaskets.
FYI, Be very careful, those doors are heavier than a dead moose! :bug:
np
have you ever had a problem with the gasification door? sometimes mine is not staying closed all the way. i lossen the nut and re tigheghten and that helps some but wasn't sure if their was another solution.
i would like to do storage someday. how is your 500 gallon pressurized working. was it hard to hook into you set up?
joe
