Ok folks, I got the stove ordered after two years of research. (Hearthstone Homestead in blue-black satin) Now I need to construct my hearthpad. I just picked up two 4 X 8 sheets of micore 300 at 1/2" thick. The scenerio is 1" high plush carpet with pad over 3/4" plywood subfloor. I have already realized that the only way I can achieve the required R-value is to rip up the subfloor.
I would like to keep the pad the same height as the carpet for asectic purpose but I don't know if I will be able to do that with such a high R-value. According to the manual this stove requires R 2.5. If I double up the micore, that will give me 2.2. Then add two 1/4 inch sheets of cement board one above and one below that brings me to 2.4 r-value and 1 & 1/2" in height. I was wondering if I could substitute some air space instead of another sheet of micore. How would I do that? With shims over the joists as spacers ?
Then to finish, a layer of porcelin tile or granite tile. Another question: I can only seem to come close to the required r-value but not complete it, anyone have any ideas or experience here?
Another question, what kind of cement board is best for this application. The manual lists durock and wonderboard, will hardibacker work ? Are all three listed as "Non-Combustible" with the NFPA ?
What tool would I use to cut the subfloor in the corners perpindicular to the wall where the circular saw won't reach?
Thanks, Holysmokers
Thanks, Holysmokers
Now I'm going to make some phone calls.
