Hello folks
I was wondering if I could get some advice from people with way more experience
Problem: Having a hard time getting the stove top over 400
Setup: Vermont Castings NC Defiant, horizontal vent, to a 8 in one piece liner. Liner is 22 ft tall in a brick and mortar chimney that is 13x13. Only the top half of the liner is wrapped in insulation since I had a narrow spot that would not allow me to get the pipe and insulation past it.
I want to start by saying that I have searched the forum archives. I have spent probably 5 hours reading through different threads. I know that many sites get annoyed at newbies for asking the same questions that have been asked a 100 times before. I may be doing my searches incorrectly but i have not found a thread similar to my question, just the opposite.
So I start to make a fire and I get it going and then add a few logs and keep the damper open and the oxygen control wide open. I have been letting the fire run this way anywhere from 30 min to an hour before i close down the damper. Looking at my instruction book for the stove it says that I should closing the damper when the stove top reaches around 350 degrees. I am having a heck of a time getting the stove to that temp.
Could my problem be wood? I am using wood that is 3 years old, the guy that sold it to me does a lot of fire wood so I am sure it has not been covered so there is going to be some moisture from weather but would a little moisture make it hard to reach temperature?
It appears that there is just not enough oxygen to get it going good. I was reading in one thread that a good draft is not achieved unless the outside temp is below 40. We have been around 45 at night could this be part of the problem?
I did find last night that I could get the stove top up to about 450 by knocking the oxygen control back to half way. this kind of confuses me since i would think more O2 would mean hotter fire.
This weekend is going to be much cooler so I would like to get the stove up to the 600 degree range so that it is producing the most heat possible. The directions say I can hit 700 without a problem but most of the time I am having a hard time getting above 350.
Any suggestions? I am sure i am doing something wrong. I also wonder if my logs could be too large and that I might be better splitting them in half but that is just an uneducated poke in the dark.
Thanks for any help!
