hello all....hope your summers are going well....i know this place is pretty quiet this time of year, but i have a questions about my pb105 that i have had for just short of a year. i am currently burning pellets for my DHW as the system I have of foinf through a bad a night. Since the fire is going out and staying cold for some time due to the lack of a heat call, when the boiler does ignite it kicks out quite a bit of smoke. i am talking about at least 10 seconds worth, now it could be this bad all the time, and i have simply never watched it that closely. once the fire is going, the smoke completely stops.
is this normal?? i believe i keep my boiler excessively clean, but could something need to be cleaned again?? this board has always been extremely helpful so i look forward to any responses......
i have a harman pb105 pellet boiler.....
i really can't compare it to other pellet boilers, but from when i went through and did the research it seemed like harman made the best boiler out there. i have my boiler connected so that it heats two zones (upstairs and downstairs) in an approx. 2000 sq. ft. home. it is a new home, well insulated and i live in northern NY. the boiler also heats my hot water. wanted to give you those facts so you could take it into account for how you compare the two homes for heating. the most i used per day, when the temps did not get above 0 in jamuary, 2009 up here, was about 3 bags/day. that did not last long though. i averaged about 2 bags/day. i love the boiler so much that i now use it in the summer to heat my DHW. i turn it on once a day to heat the water in the tank, then it is off for the day. that provides us with enough hot water for our needs. it is sooo nice being completely oil free
