Well, just broke down after all the research and decided on a Lopi Yankee Bay as I could get it installed in early January. I'm sure I could have done more research but at some point you have to pull the trigger. Not sure if I would have selected another brand but I will hopefully be pleased with this choice. I also picked up two tons of pellets from the local HD and have them patiently waiting in the basement. Can't wait to see what type of heat this unit will put out and determine if I need auxiliary fans on the first floor to spread it around.
What have others found as far as heating your homes. Mine is approximately 3700 sq ft. The stove will be located on the first floor in the rear of the house (contemporary colonial). I'm not expecting too much of the heat to get upstairs without floor registers installed (as the stairs are in the front of the house) but what can I expect on the first floor which is approximately 1600 sqft?
