Hi guys, I'm new to the site and to the wood stove world and have a couple ?'s. First I'm installing this stove in a mobile home (which according to HUD is actually a manufactured home, but same rules apply I guess). The books says I need a minimum system length of 15 ft for proper draft. Is this from end of chimney to end of outside air inlet? The book doesn't define this well, but has a diagram showing measurement from top of hearth pad to end of chimney, but I'm thinking to myself "what do the legs of the stove have to do with airflow?" Also, I have 6.5 ft of metalbestos ss chimney, but it is not on my list of "approved" chimneys. My question is, is it compatible with the metalbestos ssII? I read somewhere that the pipe itself tested good for 2100 and was approved for HT standards IF it is used with locking rings at the joints. If not what would be a good choice for a cost effective chimney system out of the following list:
ameritec dcc connector & hs chimney
duravent dvl connector & duratec or duraplus chimney
gsw super chimney 21
i.c.c. excel hp connector & 103-ht chimney
metalfab dw connector & tg chimney
oliver macleod provent pv conector & 3103 chimney
security dp connector & asht or s2100 chimney
selkirk metalbestos ds connector & ssII chimney
Sorry for the long post. I'd appreciate any advice you can give. Thanks.
-Phil
-Phil
