LOPI Pioneer Pellet Stove - constantly feeding
hangtown_ca
4
CA
Hi there.
Recently bought a house with LOPI Pioneer pellet stove. It runs but doesn’t seem to provide enough heat - bedroom of ~300 sq ft with ~15’ ceiling.
Stove powers ON, I can switch between manual and auto with no problem. No fault codes indicated.
The issues are:
- the auger keeps firing every five seconds
- the fan seem to only provide warm air on the left side, facing the stove. The right is almost room temp air - not sure if by design. I didn’t find anything about it in the manual
The auger constantly feeding causes wasted pellets and also faults as the pellets outside the firebox ignite.
I went to a local wood stove shop and was told that it’ll probably easier to replace than fix.
Thanks for any inputs.
Jo
When was the last time the stove had a full cleaning?
Last cleaning is unknown but I’m in the process of doing a full cleaning per the instruction manual. It’s the first time I used it and that’s how I found the issue.
Any specific parts or things to look for that I should focus on as far as cleaning?
Thanks again.
Just find and clean all hidden exhaust passages. Clean and oil fans if called for
