was cleaning my lopi in preparation for the coming cold spell and came across this conundrum.
my setup is outside air, vertical for 14 ft of 2in flexpipe.. my house is reasonably air tight. was checking the combustion blower and felt cold air along the base and discovered there is a rectangular hole about 2x2in(guess) in the air intake line, inside the stove framework. anytime the outside door is opened, cold air comes in. anytime the kitchen stove vent fan is turned on, cold air comes in. it seems to defeat the purpose of outside air. yes, there are burn problems. after disconnecting the outside air and blocking the flexpipe the burn is definitely affected depending whether an outside door or window is opened.
does it make sense to cover over this 2x2 hole so that outside air only would be coming in with a side benefit of no cold air entering the room? why have outside air and then compromise it with a blending setup?
i don't have a clue
yes,i'm new
i don't have a clue
yes,i'm new
