Hi All,
I am doing some maintenance to my Lopi Model X and came across a piece that has fallen off. Seems to maybe be a cover that protects a hole in the shelf that the baffle sits on? The hole seems to extend down and I assume then is connected to some tubes that finish near the front doors. There is access for air to flow through this space from within the fire (below the baffle). Anyone know anything about this?? Seems like some modification has been done by others. Maybe to clean gunk out from within the area?
So I'm thinking of just putting a plate over the hole. Mainly because the void in behind would fi up with gunk over time. What are peoples thoughts?
Thanks,
Dan
![Lopi Model X - Help Needed Lopi Model X - Help Needed](https://www.hearth.com/talk/data/attachments/294/294161-347ea4d72e8f85f7f739f47542fb07af.jpg)
Thanks,
Dan
![Lopi Model X - Help Needed Lopi Model X - Help Needed](https://www.hearth.com/talk/data/attachments/294/294156-d8d311be0f157a879892900faebde1fe.jpg)
![Lopi Model X - Help Needed Lopi Model X - Help Needed](https://www.hearth.com/talk/data/attachments/294/294157-89b703f7dd3566e22b1262b6ccbadd9b.jpg)
![Lopi Model X - Help Needed Lopi Model X - Help Needed](https://www.hearth.com/talk/data/attachments/294/294158-3f2125ec49423361ad84d00505d7a667.jpg)
![Lopi Model X - Help Needed Lopi Model X - Help Needed](https://www.hearth.com/talk/data/attachments/294/294159-3e7abfa5a8381a20caea1b281b4a3db4.jpg)
![Lopi Model X - Help Needed Lopi Model X - Help Needed](https://www.hearth.com/talk/data/attachments/294/294160-1fc2e8eeb855d50618ea068525917e1f.jpg)
