Hello,
I recently purchased a home which has a Lopi Flex 95 installed. It was installed when the home was built in the early '90s.
My concern is that there is a small gap around the top of the insert flange, ranging from 1/8" to about 1/4". I will add a picture, you can see the gap directly above the damper control. The issue is that I can see through this gap, and there is no type of connection from the top of the insert up into the chimney. With a large fire going, I can actually see the flames going up through the damper and into the chimney. This is not causing any smoke in the house or anything due to the draft, but my concern is that it is also reducing the draft efficiency of the insert, as per the manual there should be an air-tight seal, forcing the draft to pull air through the appliance. In the user manual I see there are a few different installation methods, direct connection or positive connection with an adapter piece of pipe between the insert and the chimney, or a face-seal option where there is no seal at the chimney, but there is an air-tight seal around the face. It appears I don't have either.
I honestly don't know what is above the insert. I assume it is a direct pipe up to the roof, but obviously just doesn't have any direct connection to the insert. I don't know if there is a back-off plate or anything.
Anyway, looking for opinions on how important this is to fix (if at all), and what I should do about it.
My thoughts:
1. Is there any material I could purchase to 'stuff' in the gap? Perhaps I could get it close to air tight. Since it is visible it would have to be black to match and not look terrible.
2. Fabricate a ~1" piece of steel to bolt onto the existing flange and fill the gap to the outer surround? This shouldn't be too hard. Again I assume I should have some kind of insulation material to sandwich between the flange and the new gap filler piece to really make it air-tight. The insert insulation I have found so far mostly says 225 degrees, since this is directly above the damper I imagine it gets hotter than that?
3. Fix the chimney connection. Install a piece of pipe at the top of the insert up into the chimney, and install a back-off plate or attach to the piping if it exists? This of course seems the most involved. Assuming there is either piping or a back-off plate, could I do this without removing the entire insert?
Thanks for your help.
![Lopi Insert - chimney not sealed? Lopi Insert - chimney not sealed?](https://www.hearth.com/talk/data/attachments/266/266636-a9dc436e255f35e78b635abf0776b87a.jpg)
My thoughts:
