I have a Lopi Yankee insert. It is installed with an OAK with a vertical run of 14 ft. The vent run is vertical for 18 feet with insulated 4 inch flexible stainless steel pipe.
I have programmed the control board for the small pellet stove. The reason for this is that it seems to give me better control of the air and flame. I do not have to readjust it when changing combustion levels.
With the board programmed for large stoves, which the Yankee insert is, I had to readjust it each time I changed combustion levels or I get either glass that dirties quickly (and soot) or a blowtorch.
My concern is, is there some future potential problem I may be causing or is there a safety concern?
