i have an older lopi 400 pi insert pellet stove. at the end of the year last winter the fan that blows out heat stopped kicking on. it started by getting really hot and then the fan would shut off until the stove cooled down, i am guessing it is a built in saftey type system. a few weeks later the fan that blows the heat into the room stoped turning on and now that winter will be comming up i would like to get this problem solved. the pellet feeder and exhaust fan work fine. the pellets run and burn fine. just the fan that blows heat into the room from the stove is not kicking on. it normally kicks on like 5 minutes after the stove is started and heats up. now it just doesnt come on at all. i dont know if it is a thermostat or the fan itself or something else. any help would be much appreciated.
i also could use a manual if anyone knows where i can download one from.
