I am loosing heat out my pipe. I close the damper just a little, gain a few degrees but then the pellets start to pile up and the flame is weak which leads to lower heat. So what do you think is going wrong here.
Gio said:My guess is it needs more combustion air or the stove and vent needs a good cleaning..
chrisasst said:yes, I am asking too much from my stove to heat my no insulation house. However, I feel that my stove should be putting out more than 180-190 degree heat even on high ! (pellets used = lignetics and dry creek)
jtakeman said:chrisasst said:yes, I am asking too much from my stove to heat my no insulation house. However, I feel that my stove should be putting out more than 180-190 degree heat even on high ! (pellets used = lignetics and dry creek)
Have you measured the vent heat?
chrisasst said:jtakeman said:chrisasst said:yes, I am asking too much from my stove to heat my no insulation house. However, I feel that my stove should be putting out more than 180-190 degree heat even on high ! (pellets used = lignetics and dry creek)
Yes... It is currently 165 degrees
I leaf blowd ( is that a word) today. I am currently running on high with the damper pretty much shut all the way. Pellets are not building up, been running like that for about 9 hours. The build up will happen overnight, or when I am not home. Usually when it happens. I am getting 210 degrees out of the stove. 74 degrees in ,my stove room. It is 70 degrees in my cold spot in my house. (16 degrees outside) So right now it seems to be working, until tomorrow comes.
