I picked up a used F45 about 2 years ago in like new condition. It seemed as if the loads wanted to burn from the right side, and the front since I got it, which I thought was odd. I did not remove firebrick and clean it last year, so today I thought to clean it. When I removed the firebrick I found this.
If looks as if there is a seam for construction purposes, Especially down at the bottom is looks as if one piece of the metal is notched into the other.
#1- Is this normal? It is not on the other side.
Maybe it is formed as a box and that is the seam?
#2- Is it double wall, so this is just the inner wall and at worst will only allow draft at that area?
If needed, I will disassemble further to investigate.
#3- Should I get it welded?
There is no warpage on the wall, and in all honesty, I actually burn it low.
Thanks in advance,
Brad
![20231025_134746[1].jpg 20231025_134746[1].jpg](https://www.hearth.com/talk/data/attachments/317/317332-eb870e7b7b1c8876e47fdf41f482b82a.jpg)
![Looks like my Jotul F45 Greenville has an open seam inside! What am I seeing?! Looks like my Jotul F45 Greenville has an open seam inside! What am I seeing?!](https://www.hearth.com/talk/data/attachments/317/317332-eb870e7b7b1c8876e47fdf41f482b82a.jpg)
Thanks in advance,
Brad
