Hey all!
I live in a house built into a metal airplane hangar. As part of this building I have about 60x60 space that is a big open hangar space, with ceilings 14 to 22' high.
I am in the process of insulating it. I have R30 in the ceilings, R21 in the walls, and R13.3 on the hangar door. I plan to go over the walls and door again with another R13.3 rigid foam, and seal it up.
I currently have a 5ton heatpump with two ductless heads in the space.
With the insulation about 50% done it can maintain ambient + 10-12* or so. I suspect even when fully insulated, especially on colder days this system will remain fairly under-sized.
I am considering adding a pellet stove to help with extra on-demand heat. I will generally only turn both systems on when I plan to work out there for the day. I am also considering adding a second 5 ton heat pump, but I do like how quickly a pellet can output heat and it might help get the space to temp a good bit faster.
Assuming I go this route, do you all have any recommendations for a pellet stove? Ideally it would have a larger hopper (2 bags are nice), a thermostat control, and if they exist, wifi control so I can turn it all on from the comfort of my bed. But if the latter doesn't exist then I'll get my lazy butt out there in the cold to fire it all up .
I have a ProPel 130 already in another space that works pretty well, but I see reviews are mixed, and I'm not the biggest fan of a 1-10 heat system as opposed to a targeted temp setting. But on the flip side many of the ones I see with a target temp only have a 40lb hopper.
Thanks for reading and looking forward to any advice ya'll have!
Picture for context about the type of building I'm in:
