Hello,
I'm new to this forum and I'm looking for a couple of product recommendation. I need a woodstove that is relatively portable to heat a large canvas tent in the winter. There are several options available that are designed for this exact purpose however none of them have a glass door. To me at least it seems a shame to be burning wood without being able to see the fire.
I was wondering if anybody on this forum knew of a stove that had a glass door and was relatively portable. The closest I've come with online searching is the salamander hobbit stove from the UK. I'm looking for more options due to pricing and availability. There are several cylinder stoves I can get cheaply that would work well if I could retrofit a door with a window.
As a second request, I'm looking to upgrade my fireplace situation at home. I currently have an inefficient zero clearance on the main floor and a second chimney in the basement that has nothing attached to it. I'd like to increase the heating ability of the zero clearance on the main floor with minimal expense. The chimney is a double wall but I don't know what I can put in the space.
The basement chimney also appears to be a double wall. Can I just hook up a wood stove to the existing chimney? I attached an image of the basement chimney.
Thanks in advance for the advice.
Garrick.
Garrick.
