Bottom Line Up Front: Looking to chew the fat and get some ideas about what I could with existing space. Do I close off the fireplace, paint the brick (shudder) and install a free standing stove? Do I try to find an insert? Do I redo all the masonry, including adding a raised hearth and larger firebox? See picture to get the ideas flowing (shown with the existing stove/insert slid out). Also, I'm interested in hearing brand recommendations.
Details and Introduction:
First time poster but learned a lot browsing the forum over the past few months. My wife and I just moved to a very modest sized (1750 sqft.) house built in 1982 (located in Seacoast NH). We're working on our "10 year plan" for things we want to update / expand / repair / etc. and one of the areas pretty high on the priority list is the hearth.
I previously renovated and lived about a decade in an 1880s house, about 2500 sqft. with a Hearthstone woodstove, which had secondary combustion. I don't recall the model (it was already in the house when I bought the place) but I loved it. It was my primary and sometimes (during renovations) only heat source. Burned beautifully, easy to control, good even heat. Before that, I lived in central Indiana in a 1952 ranch. I installed a wood-fired furnace in the basement, which included doing all the masonry and installing a stainless steel liner. So I'm reasonably handy and know some basics but certainly not a pro.
Back to our current house: the previous owners had a Lopi Premier Answer series stove configured as an insert installed in the fireplace. It is pretty tiny, only accepts small logs, and just doesn't look that good. What's more, the gaskets are all shot, every single firebrick in the firebox has multiple cracks / is crumbling, some of the welds holding the convection panel in place are broken (the panels have "sprung") and the screws holding the glass on have broken off in the brass surround. I've got a machine shop and welders so I could rebuild this stove but... I just don't think it's worth it.
As a near term solution (winter is coming!), I was thinking about buying a used stove from Facebook Marketplace or Craigslist. I've noticed tons of Vermont Castings stoves available but, after reading on this forum, I don't think I want one of those. Excluding those significantly reduces the options and increases the cost.
Anyway, buy a "cheap" used stove, pipe it into the existing stainless steel liner, maybe prime and paint the brick white to better fit the planned color scheme / interior decoration of the house (I guess one would consider it "modern coastal"??). Due to the low height of the existing firebox / smoke shelf, I'm thinking about cutting a hole in the masonry above the smoke shelf and connecting to the liner there. At which point, I might as well close off the alcove / existing firebox entirely and just make that an accent wall with a free standing stove.
Downsides of the above suggestion:
1) I hate painted brick. Maybe I like it better than the current brick with the weird white splotches, but it just feels "wrong" to me
2) The stove will be proud of the existing firebox, which is sort of a problem because the room is narrow and deep. We had planned on putting chairs on either side of the fireplace but with the clearances needed for a woodstove, it pretty much rules that out. Even if you could fit a chair, anyone sitting there will get roasted if the stove is a good radiator... and if it's going to be free standing I want it to be a good radiator!
So then I started thinking about a good insert (care to recommend any brands?)... and then I started thinking about rebuilding it with a larger firebox and maybe a raised hearth so the insert would be more of a focal point in the room. Then I started thinking about pulling out all the brick and redoing it with flagstone... and everything just sort of snowballed. So here I am, looking for inspiration and advice. Ideally, I'd like a cheap "this year" solution and then a longer term goal in which I would consider more drastic changes. FWIW, the exterior portion of the chimney houses two additional flues, one each for furnace and water heater.
![[Hearth.com] Looking for Inspiration: Hearth Redesign [Hearth.com] Looking for Inspiration: Hearth Redesign](https://www.hearth.com/talk/data/attachments/330/330055-62a53ae4ad3b8ba7f0818d98c6d3e36f.jpg?hash=NviZ8YOuYh)
