Hello all im new to this forum, I wished I had found this site a long time ago. Ive done some reading on it and seen alot of useful information but none that directly speak to what I am trying to do, which is understand how the unit works so I can correctly set it up and get it running.
We bought a used AOB24W which was hooked up but drained and not used for many years as the new owners of the house have a child with a breathing condition. Unit looks great physically, hopefully it is water tight too. Oil is getting outragous to pay for and we have 50 acers of land and now supplement with a wood stove in the basement but want to try and lower the oil use with a wood boiler instead, probabaly wont feel the same but hopefully will feel better on our wallet!
Using the diagram on the marathon website I understand how to plumb the unit up but have questions about the controls and settings.
There are two aqustats on the boiler, one right on the top with the probe going into the tank, and a second one on the top pipe (the diagram calls supply)
http://www.marathonheaterco.com/diagram_addon.html
One Im assuming is to control the loop circulator pump, and the second im assuming is an overtemp control, IE when the temp reaches X activate the bypass zone, or just active a zone valve correct?
My Oil boiler aquastat is set for a low turn on of 170 and a high turn off of 200, dont remember what the diff was, I think 15%.
My questions are this:
Which aquastat should be used to control the circulator pump, the one right on the tank? What temperature shoud it be set to turn the pump on at? My understanding is it should be a temperature slightly higher than the burner on temp (170) so set the circulator to turn on at say 175 degrees?
The second aquastat (on the supply pipe) what is it used for and what temp do I set it to activate at? I think its for the bypass /dump zone but I dont know what temperature to have it turn on at 220??
Next the boiler uses a non-electric automatic draft regulator, guessing its bi-metal unit of some sort. It has a long arm with a chain connecting it to the draft door at the bottom. Mine reguardless of where I turn the temp nob has the arm down and the draft door closed. Im assuming with no fire in it the arm should be all the way up and the chain adjusted so the draft door is wide open, then as a fire inside heats it up the arm would lower and close the door correct? I see a set screw on the backside of the arm, can I just loosen that and set the arm up when its cold and retighten it to set it up correctly?
Ive read on this site that Marathon says no chimney draft control is needed but someone stated they put one in to assist in regulating the fire for longer burns, I was thinking it would be wise to have one just for safty sake in case it was a run away fire.
What temperature should I run the boiler at? THere is a nice temp gauge on the unit im guessing its important to run it at a correct temperature.
Lastly does anyone have the manual for the Logwood add-on boiler? Could someone email me a scanned copy of them?
Your help wll be much appreciated!!
~ Phil
~ Phil
