Hi everyone,
I was referred here from an unrelated forum for some quality advice on my situation!
We just started construction on a total ICF walkout basement home. The basement walls, cap over the basement/ground floor, upper story walls, and roof will all be ICF. Foam and concrete everywhere, which presents a few challenges. We will have 2000sq ft in the basement and 2200sq ft on top of that of conditioned space.
I want a wood stove for backup/supplemental heat to our forced air HVAC system. If I don't mind the work of wood processing I may use it more full time.
Originally we planned to have a wood stove or fireplace upstairs in a living room, but as the house design changed we ended up with a clerestory roof design, and the chimney would exit in the middle of the low side roof, and on the front of the house. It would be hard to make it look good there.
I then started thinking with an unisulated slab on the basement it may actually be the coldest part of the house, and we could have the stove on the walkout wall side, this also puts the chimney in a position to run straight up and end up on the high side of the roof and the back of the house. Only downside is a long chimney run up and out through 2 layers of concrete and foam. Also worried about getting too hot in the basement and getting air exchange with the upstairs. This stove location is drawn in on the attached floor plans below.
I hope this all made sense, I'm typing quickly from my phone before I head out to start the first day of wheat harvest on the farm. I will check back in later and update as needed!
Thanks
![Screenshot_20230613-145432_Drive.jpg Screenshot_20230613-145432_Drive.jpg](https://www.hearth.com/talk/data/attachments/313/313342-7ced202eee1c5f97e9c3ab67bce8b44d.jpg)
Thanks
![Screenshot_20230613-145415_Drive.jpg Screenshot_20230613-145415_Drive.jpg](https://www.hearth.com/talk/data/attachments/313/313339-d3f9d541ba0491c3dbd40567eb8bcc4c.jpg)
![Screenshot_20230613-145421_Drive.jpg Screenshot_20230613-145421_Drive.jpg](https://www.hearth.com/talk/data/attachments/313/313341-5e76302a94afcc5061ca2bbba69e6444.jpg)
