I have a detached garage that has radiant heat loops installed in the concrete floor which is also insulated on the bottom. This was professionally installed, the piping currently is not hooked up to a heat source and is empty. The sides of the floor are not insulated but at the time I was completely uninformed and the contractor obviously was as well in that reguard.
I want to keep the floor heated at a very low temp to (IE above freezing) and then a few weeks in the winter when Im projecting in the garage, bring it up to a comfortable working temp, IE 55-60 degrees. I currently heat it with a LP can heater but laying on 10 deg concrete floor is tough on the body!
Ive read and heard alot of cons of filling a system with Glycol but since I dont want to heat it all the time to a temp id feel safe wont freeze.
So if you have a system with Glycol in it would you mind answering a few questions?
Glycol Survey
- What is your area's expected outside low temperture?
- What ratio of glycol is your system filled with?
- What type of water did you use to fill it? From the Well if so is it hard or soft? Or distilled water?
- What type of glycol solution did you use? IE is is an uninhibited generic type that sells for $25-40 a gallon or a name brand inhibited solution from say Dow like DowTherm or DowFrost that costs aprox $100 a gallon?
Link to these products:
http://www.dow.com/heattrans/prod/glycol/
- How long has your system been running with this current fill of glycol?
- How often do you have to do MAINTENANCE to the glycol and what do you do?
- If you have refilled your system how long did it go on the first batch of glycol?
- What is your heating system components comprised of? IE PEX, Copper, Black Pipe so on....
- Other comments/personal experiences?
Thanks Guys
~ Phil
Glycol Survey
Thanks Guys
~ Phil
