Looking for any info on my Unique fireplace.
AdrianCT
1
CT
I have not seen this any where.
It’s very efficient, since it is fed by outside air from the bottom. The room air feeds in to the bottom and goes around the inner chamber. Then around the chimney, venting at the top. Thanks for any info.
that looks kinda to close to the wall i don't know if i would want tire fire it off that close to the wall.
That is a cool looking stove. Check out the clearances on this unit. That is nuts. I can't see how that is safe. I can only assume those clearances have to be modified since the original manual. I pulled this from the manual in the link beholler provided.
The stove's air jacket keeps surface temps lower and less radiant.
all i have to say with those clearances is wow
