Hello
Looks like an older Fasco where you can see the shaft turning at the very end. I used 3-1 oil on it to quiet it down.
If I need a new exhaust blower then what is the cheapest way to replace it?
Maybe someone at Fasco Distribution can xRef it?
http://www.fasco.com • 800-325-8313 • fax 800-352-7207
The specs are FASCO Model 702111383 115 VAC 0.6A Type U21B 60 HZ 3,000 RPM
Quadrafire Part # 812-3381 with a diameter of 5 inches between the mounting screws. See red arrow in pic below:
Mountain View Hearth has it for $330
but I do not need the housing just the FASCO blower motor and maybe fan blades??
http://www.stove-parts-unlimited.com/Quadra_Fire_1200_Exhaust_Blower_p/812-3381.htm
The diameter of the motor casing is 3.3 inches
The distance between the 3 holes shown by the blue arrows are approx 2 and 3/4 inches
Looks like a D202 in this FASCO pdf?
http://www.fasco.com/documents/pgs022-030.pdf
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
