I am looking at purchasing a outdoor boiler, and there are so many different companies out there.
I talk to Central Boiler and they say theres is the best because of the firebox design, and it is the only boiler with the blown on insulation.
I talk to another company and they say that the square firebox's are no good that you need to go with a round one. And that Vat insulation is better, because the blown on insulation will get moisture under it and rot the water tank out.
The next company says a stainless firebox is the way to go.
Then the next company says that stainless is not the way to go because it does not transfer heat as well as mild steel, and it will expand and contract more than mild steel and will get fatigue.
So, who do I believe? I can see everyones point on why theres is better than the next guy's, but I just want to know what will work the best.
Then I also have the option of saving about $3000+ and getting a "knock-off" brand. These are the companies that say their boiler is built just like so and so's but way cheaper. On one hand I want to get one from one of the big companies, but on the other hand I could save a bunch of money and go with a cheap one. But I do know if I run into problems the big guys will stand by there product where the fly by night guys probly will not even be around next year. But, I am also good at welding and reparing things, and I would imagine that about the only thing that could go wrong with a boiler is a weld failing or something else that I can fix. And all the pumps and electrical componants could be fixed easly.
What do you guys recomend?
I am sure it is asked all the time, but what brand do you recomend too?
Sorry I am new here....
Thanks
Ross
Thanks
Ross
