I am a renter and my landlord installed a wood stove in my fireplace fall 2016. I am realizing that although it's a solution, I'd really like (need?) a better solution. The stove I have is no longer listed on the manufacturer's website, but I did find it here.
The stove is appropriately sized for my house, which is about 900 sq ft, although about 1/3-1/2 of that is shut off most of the time. I do struggle with getting heat around corners and into a back bedroom but it's a problem I'm ok with and am actively working on fixing.
The stove has no fire brick. Therefore, I find it has to be constantly tended or it will go out. I'd like to have a stove with brick so that I can load it up before I go to bed and have heat through the night. I am finding that at some point during the night the house cools down enough that the central heat kicks on. I'd like to avoid that. I have several cords of good seasoned wood that I got for free so why should I pay for heat?
The stove has no air controls beyond a flue mounted damper (which I'm not sure is operating correctly 100% of the time). Therefore, I regulate the air by opening or blocking the two holes on the face of the stove with magnets as well as opening or blocking the space at the bottom of the door with a piece of foil. It's crude, but it works. It would be nice to have actual air controls. Along this line it would be nice to have a stove that has a door gasket as I feel that helps with controlling the airflow.
The stove has no legs in its current installation because apparently it would have been too tall. I was not home when it was installed so I am not sure exactly what the issue was. Due to its lack of legs it is sitting flush on the floor of the fireplace which means I have to get down on the floor every time I want to start a fire, feed the fire, check the fire, etc. This is difficult for me to do. I'd like to have a stove that I don't have to do gymnastics with.
The stove has no ash drawer, which results in obvious complications when it comes to keeping the stove clean. Usually I end up shoveling out as much as I can and then leaving it outside for a few days in a metal container before burying it in the woods. Rarely do I have coals left the day after a fire but better safe than sorry.
Interestingly the front of the stove hangs out of the fireplace over the floor. The majority of the flat loading area is what is hanging out. I see this as a fire hazard since sparks might fly out and land on the floor. I did have a fire resistant rug on the floor underneath/in front of the stove but my cats thought it was a great toy and quickly destroyed it. I think it would be better to have a stove that fits in the fireplace completely. I suspect the issue I'm having is because the stove has a narrow width and is quite deep. It is a N/S rather than an E/W.
I noted on an informational page associated with this forum "Code also requires the Damper area to be blocked off" and "The code calls for closing off the Damper area with a metal plate." There is a mention of NFPA but I am unable to find the specific code section that is relative to this (I did read through the 2016 edition of NFPA 211 as it pertains to fireplaces and stoves). There is no blocking plate installed, instead the stove is attached to a liner that appears to go through the damper and straight up the chimney. I'm guessing this is something I need to rectify.
I doubt there is any money available to me from the landlord for this endeavor so I'd like to know where to look for an inexpensive used stove that would work for this situation in addition to what stove to look for. Ideally I would try to sell the one I have to use that money towards another but I'm not sure anyone would want this stove.
I'm sure there is information needed that I didn't cover so please ask questions. I've included a picture of the current installation (below) and, yes, I know there should not be wood next to the stove but it is on its way in. Thank you for any help, advice, direction, etc. you can give.
![Looking for a better solution Looking for a better solution](https://www.hearth.com/talk/data/attachments/222/222434-70f95c2ef7e36667b40f400d8dbda46b.jpg)
