I would love some input from others with a 91 as far as whether it is overkill for my setup. I'm trying to avoid a stove that puts out so much heat that we can't use it often. I'd really appreciate any perspective from current 91 users.
Based on availability in my area I've narrowed down selection of a new wood insert to a Buck Stove model 91 or was also considering a PE Summit. The 91 will fit in our large fireplace, but I am mainly worried it will put out "too much" heat when operated normally and roast us out of that end of the house. Local dealer says I can always build a smaller fire but I'm skeptical about how well that will really work. We're in MD, so we have a winter but it isn't as cold as many areas, and I'm not necessarily trying to make wood our primary heat source but I wouldn't mind getting as much heat as we comfortably can out of it.
The house is a 1963 Ranch style house with rather large fireplace at one end (the existing flue is an amazing 16" diameter terra cotta liner) + mostly finished basement downstairs. About 1500 sq feet upstairs and the same footprint downstairs as partially finished basement. We have a single zone of forced air (currently just for AC) throughout the house, so some ability to circulate air but the air handler is all the way over above the garage, so will likely lose some heat using that. The vents and returns are all in the ceiling, so more ideal for cooling but thats what we have.
The existing fireplace is so big that I'm trying to avoid putting too small of a unit in that would look funny with a large and plain surround but also trying to balance that with potential heat output of a larger insert. I'd like to be able to run the stove "low and slow" when it isn't super cold out and of course still enjoy the look of a fire more often throughout the cold season. Fireplace dimensions and rough house layout below, and thanks in advance for any suggestions you might have.
![[Hearth.com] Looking at a Buck Stove Model 91 - Concerned it is Overkill [Hearth.com] Looking at a Buck Stove Model 91 - Concerned it is Overkill](https://www.hearth.com/talk/data/attachments/304/304749-99a754934a64f76151d4160fd31460e4.jpg?hash=05CNfkNLPM)
![[Hearth.com] Looking at a Buck Stove Model 91 - Concerned it is Overkill [Hearth.com] Looking at a Buck Stove Model 91 - Concerned it is Overkill](https://www.hearth.com/talk/data/attachments/304/304750-86ba086aa994087859cc87ef021a7143.jpg?hash=cy2nGAmF8_)
