look inside my BUCK 91
trx680
101
Petersburg Virginia
I'm finally getting my used Buck 91 ready....after putting it off for 7 months.
I took some pics of the inside. I have to replace the cotter pins on the back of the plate, as you can see the back is sagging.
The plate is warped but I would imagine that is common?????
What about the catalytic combustor? I've never seen one before so I'm not sure if its looking normal or ....
thanks!!
im not seeing the pics
yea, guess that would help..lol
[Hearth.com] look inside my BUCK 91 [Hearth.com] look inside my BUCK 91 [Hearth.com] look inside my BUCK 91
Did the back not have washers & Pins?? That's why its sagging..... However, I have only had a few small fires in mine and it looks like the back of that baffle is warped... could be discoloration, i'll have to check....does yours have fire brick???
No washers. The front had pins as seen. The back baffle somehow fell past the pins, but the pins where there. I'll get new pins and washers.
Firebrick----yes. I'll vacuum it out tomorrow and take a pic
