lets assume the load is 6' high 7.5' wide and 24' long = 8 to 9 cords cut and split less.
If the logging trailer has no grapling arm then plan on a folk lift to unload Most or none tilt or dump
A tri-axle log truck without a loader will hold about 7.5 full cords. If there's no loader, then the load has to be dumped in your yard. I think $1,400 is about 2 or 3 times more than you should be paying for a load of birch. $500-$700 would be more like it.
If the truck has a loader on it, that knocks about a cord off the load.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
