nwohguy said:
Thanks for the advice. I have been using the wedge, that way i can place where the split will occur. By swinging a maul, my aim on the log might not be very accurate. I guess it will come after experience. Most of the logs are no longer than 17 inches long, 12' - 14" wide. How many swings will it take typically to split somthing that size? I'm not sure what type of wood it was that i was working on this weekend, but it would not split. No bark, very smooth outside and yellow or white color inside. I thought it was ash. it was a tall tree, 50 ft with truck about 30 inches.
Welcome to the forum nwohguy.
Contrary to what Wood Duck stated, everybody does not like the Fiskar's axe. I will not use one myself. I think with the short handle that they are too dangerous.
To attempt to answer your questions, you must realize that every type of wood has its own characteristics. Ash does not split like oak doesn't split like beech doesn't split like locust, etc., etc. It takes a little time for new people to learn the ins and outs.
I have done a lot of splitting with a sledge and wedge and also just with a single bit or double bitted axe. When I split with a sledge and wedge I had 3 wedges. Two were the same but the third one had less taper to it. This one I sharpened a bit so if one of those logs you could not get a wedge started, I'd simply grab the sharper one and hit it a time or two with the sledge (while hanging onto the wedge). I had no problem doing it this way. The other two wedges would sometimes be used in the same log or sometimes I'd get a wedge stuck (that is interesting the first time it happens to you). If you get one stuck, simply drive another right beside it to open the crack wider and most times that will finish the job.
Lots of wood can be split simply with a regular axe. It all depends on what you are splitting. Also it depends on the wood type as to the best way to split. For example, most times beech and elm want to be split on the sides and not through the heart. You'll learn these things as you go and experiment.
Another little hint. A lot of folks when they have someone new to splitting, they will wrap the handle of the axe, maul or sledge with wire. Then if they miss, they won't ruin the handle.
I've graduated to hydraulics due to what my body can or cannot do now. It surely makes life easier, but I do miss the splitting by hand.
Good luck to you.
