Hey everybody, first post so go easy! I don't know a whole lot about hydraulics but I will try to describe the problem as best I can.
So I picked up an older, very heavy duty, homemade log splitter from Craigslist the other day. The seller and I thoroughly tested the machine by splitting a whole bunch of hickory and oak logs from his wood pile, so it was working fine when I left his place. Then a couple days went by before I could actually use it at home. Today, when I tried splitting some wood, it was being REALLY temperamental, and it seems like an unusual problem.
The only way I can get the cylinder to have enough force to push through a piece of wood is to slow the engine WAY down. At a certain speed, my guess is around 1200 RPM (just by ear, haven't connected a tach yet), I can hear the system start to build pressure and the cylinder powers forward through the log at a pretty decent pace. I hear a "whooshing" or "whining" noise when it starts working. Like all of a sudden it realizes it needs to build pressure. Of course since the engine RPM is so low when the load is added, the engine wants to stall so I have to raise the throttle to compensate. MOST of the time, I can make it the whole way through the split by manipulating the throttle, but sometimes the governor wants to give it too much throttle so I lose all my pressure (and also all the noise in the hydraulic system).
At "normal" operating speed (which I assume is somewhere between 2000-2800 RPM), the cylinder will move back and forth but very slowly. It just won't split anything. Another symptom I notice is that the engine will actually bog down more when the cylinder is RETRACTING than it does when it is advancing.
The parts used on this homemade splitter are really hard to identify because there are lots of missing tags and lots of layers of paint. Here's what I know:
Engine is a Wisconsin TJD 18.2 HP inline twin which runs great, so it should have PLENTY of power.
The cylinder is made by Parker Hannifin, has a 6" bore, 24" stroke, and the rod appears to be almost 2" in diameter.
I have no idea about the pump specs, because I cannot find any nameplate.The control valve is made by Prince.
It really is a beast and I got one this big for a reason: lots of big chunks of maple I just can't split with a maul. Really hoping it's something simple and not an expensive repair.
Is this a symptom of air or water in the system? Fluid flush/change first in order?
