Hey guys what is your opinions on the max log diameter i should be putting into my insert? I have a insert that will take 18" wood. I know i prob. want some of the logs for overnite burns, but what is too big a diameter to be efficient?
burntime said:You opened it up when you split it. The bark on the smaller pieces kept the moisture sealed. Thats your difference...
burntime said:Yes, rounds dry slower... Thats because the bark seals it in. You are 100% correct, more surface area dries faster...
burntime said:Andy, I gotta disagree with you on that one. In the same species the larger will ALWAYS take longer to dry.
I like this method. It's probably necessary for those who need to hold with one hand while they load it into the stove. For my fireplace I never worried about it. since everything sits lateral to the opening with plenty of room on the sides you could hold both ends and toss it in. with a stove, even one that loads from the front in an E-W manner, there isn't enough room to get both hands on the ends to put it into the stove.gzecc said:I loosly use that "hold it in one hand from the end" technigue, but then I wonder how long I should be able to hold it. Everything is so complicated. An ash split that I can hold is nothing compared in weight, to a black locust or oak split.
A 6x18 log has a volume of 508cubic inchesafblue said:Rounds to Rounds the larger full round will dry faster because the ratio of bark on the outside to the cross sectional area of the log.
6"x18" round
Bark surface area=(pi)DxL= 3.14X6X18= 339.12Sq in
End surface area=2(pi)r^2= 2x3.14x3^2=56.52x2 sides= 113.04 sq in
3:1 bark to cut end ratio
12"x18" round
Bark=3.14x12x18=678.24 sq in
ends=2x3.14x6^2x2=452.16 sq in
1.5:1 bark to cut end ratio.
24x18" round
bark 1356.48 sq in
ends 1808.64
.75:1 bark to cut end ratio
Therefore a cut round: 2X the diameter has 2x the cut end surface area. Its not magic, its math.
Spliting any log will increase the surface area and decrease drying time.
