- Oct 3, 2007
- 1,539
A while back there was a debate going on about ICFs (Insulated Concrete Forms) and other types of high efficiency insulation/construction methods. SIPs are the pre-fabbed panels made from OSB on either side and high r-value foam insulation in the middle which create a strong, airtight, and highly insulated wall. Most are rated around R-30/R-40 depending on thickness and type of foam. Anyway, SIPs are nice, but my wife and I have always wanted to build a log cabin. Log cabin walls only rate about R-8 because solid wood is about R-1 per inch. Some folks do log cabins this way by constructing outer log walls, applying foam insulation to the inside, and covering it with sheetrock, but we want the log look inside just as much as the outside, so I started thinking.
What if you could construct inner and outer log walls (both 8" thick, which would create an R-16 wall right off the bat) and fill the center void (also 8") with expanding spray foam like the type that is typically used in stick framing? Most closed cell spray foams are rated around R-6 per inch. The other advantage of expanding spray foams are that they fill gaps that normally wouldn't be able to be filled, so zero air infiltration/leakage can be achieved. The resulting wall would be just over R-60! The only other construction methods I've seen with that type of rating are straw bale/stucco homes. Conventional OSB/foam SIPs could be used for the roof. I just wonder at that point, in our climate (Northwestern New Jersey, where -10 is about as cold as it ever gets, and even that is rare), what kind of heating system would that require? Would even a small wood boiler cook us out of the house? The air conditioning bill would be pretty nice I would imagine
Obviously construction costs would be an issue, but our length of return on investment would be high-whenever we build our home we intend to be there til the end, come hell or high water. Just curious to see what others think of the idea, or if anyone has heard of anything similar?
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
