I have asked this question before, but I didn't get a clear answer.
Last year I ran my DHW sidearm continuously - as long as there was a fire in the boiler, the main circ ran, there was flow in the loop and through the sidearm.
This year, I am changing the configuration of the system to zone flow and the main circ will only run when the zones call for heat. I want to set up the DHW tank as a zone, so that loop water will flow through when the tank temp drops below a set temp.
Flow in my electric DHW tank is from bottom to top, fairly stratified. The tank is new and well insulated.
My thought is to put a 120* disc sensor about 1/3 up the tank, on the outside, under the insulation. Since the temp in the tank is always higher (at least 140*) when using the sidearm, the zone would only come on when the tank drops below 120* in the bottom third - leaving 2/3 of a tank of hotter water at the top.
Thoughts on this?
Thoughts on this?
